Fuse Box and Relay Location
MERCEDES BENZ
ED51
  • 16 POSTS
1997 E420, auto, gas, 113,225 miles. Is there another fuse box located inside the car? Where is it located? There is only on fuse box that I can find and it is in the engine compartment on the driver side. Also, where are the relays located? Thank you for your assistance.
Jul 27, 2007 at 3:02 AM
RICKSZAT
There is another fuse box on the side of the dashboard - drivers side. When you open the drive door, you can use your key to pry off the top. Generally has fuses for the various lights in here.
Aug 21, 2007 at 8:06 AM
