1993 Mercedes 190E Engine Shuts Off
MERCEDES BENZ
MANGO
I have a Mercedes 190E 2.3 1993 with about 120000 miles. Recently the car start to turn off the engine as I'm driving and right after I can star and go.
I seems some related with electronics, because sometimes , I can go fews days with no problem.
In another words its happen on and off.
Thank you very much
Oct 17, 2007 at 10:15 PM
SERVICE WRITER
  • 9,123 POSTS
Intermittant stalling problems can be a real challenge. It may be electronic in nature that is affecting a lack of spark and or fuel. I would first make sure that the simple things are in order first such as complete tune up is current, making sure the vacuum hoses are all good. You can wiggle them as well as various electrical harness while it's running to see if any changes happen. This may be a situation where wind draft, bumps, heat etc. is affecting it only while its movng.
Oct 17, 2007 at 11:18 PM
Suggested Repair
Start with a current tune-up and inspect vacuum hoses. With the engine running, wiggle vacuum lines and electrical harnesses to look for an intermittent spark or fuel fault that appears with movement, heat, or vibration.
Conversation Summary
A 1993 Mercedes-Benz 190E 2.3 with about 120,000 miles intermittently shuts off while driving and can be restarted immediately afterward. The problem comes and goes, sometimes staying away for days, and the owner suspects electronics. The expert says intermittent stalling can involve spark or fuel and recommends confirming the tune-up, checking vacuum hoses, and wiggling hoses and wiring while running, since wind, bumps, or heat may trigger it only while moving.
