engine overheating
MERCEDES BENZ
ZX1
Hi its my first post i have a 1972 mercedes 230/6
the radiator pipe bust yesterday and it over heated right up to the red now i repaired the pipe an filled with water i left the cap of and started it the water runs out of the cap .i know thats not good news as it might need a new gasket an head pulled off .but a friend of mine said that i must bleed the water system ?i noticed on the thermostat housing ther is a nut now how do i bleed this system i'v never heard of this before please can you give me some info as i dont want to pull the head off . thanks in advance
Nov 9, 2006 at 8:21 PM
2CARPRO JACK
  • 11,533 POSTS
Engine off, remove the nut ad fill the radiator until coolant comes out of the hole
Nov 16, 2006 at 2:36 AM
ZX1
[quote:726e21c604="2CarPro Jack"]Engine off, remove the nut ad fill the radiator until coolant comes out of the hole[/quote:726e21c604]
Thanks i did that and it works perfectly does not
overheat and its running sweeeeet . For now anyway
Nov 17, 2006 at 6:27 AM
