Climate control problems, Interior gets too hot and too cold
BERTROBINSON7
  • MERCEDES BENZ
I have a 1995 C280 and ear temperature inside constantly gets very hot And then completely shuts off and gets very cold from outside air.
Does anyone know why he can't maintain a steady temperature assets on the inside temperature control.
Sunday, April 9th, 2006 AT 9:45 AM
BENZ_GUY
  • 28 POSTS
It sounds like you have a faulty interior temp sensor.
If you go to this link I've (SL600_Cruzin) posted a really long description of how to check all of the parameters using the built-in climate control diagnostics for both the early and late 1995 C280 models. You can do this "without" the use of a scan tool.
Also check these values when the car is cold, interior and exterior temp values should be pretty close (as long as the car is not parked in the sun). If you see a sensor that looks out of line it should help direct you to the problem.
If you need more help or cannot get to the link please let me know and I'll try to help.
Cheers
Wednesday, April 12th, 2006 AT 12:53 AM
