C180 Merc 94 model 220,000 mileage 1.8 liters
1918 MERCEDES BENZ
BONG NALDOZA
The steering wheel locked and then the start of the trouble. The ignition swith wont turn and its been over 24 hours now that I attempt to turn it and its not happening. I am so desperate. Battery is new and only the ignition swith stuff up.
Please help.
Aug 17, 2007 at 8:27 PM
SERVICE WRITER
  • 9,123 POSTS
Try to pull to the right or to the left on the steering wheel, and then turn the ignition switch while holding pressure on the steering wheel.
Aug 17, 2007 at 11:50 PM
BONG NALDOZA
I have tried it several times but still not working. Any other alternative? I had the front wheels lifted and left it hanging but still wont turn. I have tried spraying the ignition switch with an anti-corrosive spray but still not turning.
Is there any alternative way to have this ignition turn?
thank you.
Aug 18, 2007 at 10:01 AM
SERVICE WRITER
  • 9,123 POSTS
yiu probavly need a new ignition lock cylinder by the sounds of it
Aug 18, 2007 at 11:43 AM
BONG NALDOZA
Hi Paul,
Thanks. I believe that would be the solution. But I dunno what an ignition lock cylinder is and where can I purchase it? Is it easy to unistall and install?
Thanks.
Aug 18, 2007 at 2:58 PM
SERVICE WRITER
  • 9,123 POSTS
[quote:fe3bfa31b0="Bong Naldoza"]Hi Paul,
Thanks.[/quote:fe3bfa31b0]
Bong...
I am certainly not trying to offend you in anyway. Think about what you wrote, You think that part X is bad becasue some jerk from Niagara Falls THINKS this may be the problem?
I strongly suggest that you have it towed to a shop and have them find out the true reason. I'm here to help you. My assumptions over the net are not good enough in this case. My suspicions may be correct, but what if they aren't? It may cost you more to screw around than to have it done. I'll do what you want and help as I can, but this needs to be looked at...which I can't do over the net.
Aug 18, 2007 at 3:43 PM
BONG NALDOZA
Paul,
Thanks buddy!
I will have it looked by a mechanic here. I will share what to do when the mechanic find out what really is the cause of the problem.
All the Best!
Aug 18, 2007 at 8:20 PM
SERVICE WRITER
  • 9,123 POSTS
IT really is in your best interest. There are some GMs for example that have a shift interlock mechanism that can cause the problem too. This isn't something that I can guide you through over the net. I certainly don't want to come across in the wrong way. I have a responsibility to not make your life more difficult, and I think it would go in that directon in this particular case. Looking forward to what you learn.
Aug 18, 2007 at 11:53 PM
