adjust idle on 1996 Mercedes 220 4 cylinder gas engine
1996 MERCEDES BENZ
LARRYWAG
My 1996 Mercedes 220 4 cylinder fuel injection gas engine stalls at intersections because it is idling too slow. I cannot find a traditional type idle speed adjustment screw. Can you advise me on adjusting the idle speed? I found a thumbscrew type adjuster that goes around the end of the throttle cable, but when I turn it only slightly, the engine speeds up too much to around 14000 rpm, yet if I back it off slightly, the engine idle speed returns to a too slow idle speed. Currently it idles at only 6000 rpm. I'd like to boost it up to around 9000 rpm.
Jun 7, 2006 at 12:11 PM
DR LOOT
  • 2,311 POSTS
to begin with, the idle adjustment on your Mercedes is computer-controlled, therefore you have another malfunction, that's causing your idle speed to drop, you better take it into a shop, and have it diagnosed.
Mar 25, 2009 at 12:06 PM
