2007 E350 Check Engine Light
2007 MERCEDES BENZ
CCONEAL
I have a 2007 Mercedes E350 and the 'Check Engine Light' is on. My question is if there is a way to check for problem codes without using a code scanner. Last time I brought my car in, it looked like the service manager was able to access the problem codes by pressing a combination of buttons in the car and looking at the code on the instrument cluster display screen.
My car seems to run just fine and, since I'm 90 miles from the nearest service center, I don't want to waste the time making a special trip if this is nothing more than a gas cap sensor...
Nov 25, 2007 at 1:17 AM
GFIMOTORCARS
  • 673 POSTS
The instrument cluster display can be used to check some vehicle data but does not display any troubleshooting codes that a scanner would give you. Unfortunately you will need a scanner to check a check engine light.
Mar 6, 2009 at 4:10 PM
