2006 Other Mercedes Benz Models Check Engine Light - 06 Merc
2006 MERCEDES BENZ
26,000 MILES • V8 • 2WD • AUTOMATIC
JWETCHER
The check engine light has been lighting up since I purchased the vehicle, about 18 months ago. It has been in the shop 7 times and ecery time code P0456 comes up in the diagnostic test. I have been told this code is for a vacuum leak or some other type of leak, I am not sure. When the leak test is done, nothing comes up and Mercedes Service says they do not know what to do. They have opened an escalation ticket with Mercedes Benz 5 times and so far I have not received any answers. Do you know what this code means? I would like to get the car repaired as I really like it, but I cannot keep the car with the check engfine light on. I am considering filing a lemon law claim, but really do not want to go throught he hassles. Any info you can give me would be greatly appreciated.
Thank you,
Jay Wetcher
Dec 26, 2008 at 11:38 PM
BMRFIXIT
  • 19,053 POSTS
I would check with another Benz dealer
as it clear in this TSB that they have a recall on the subject
and for them not to be able to find it make me wonder if they are really trying
I will include the recall TSB
good luck
Page 1 of 3 DIAGNOSIS IN DAS FOR PURGE SYSTEM CODES / CHECK ENGINE LIGHT ILL ...
DIAGNOSIS IN DAS FOR PURGE SYSTEM CODES / CHECK ENGINE LIGHT ILLUMINATED
TECHNICAL SERVICE BULLETIN
Reference Number(s): P-B-07.61/74, Date of Issue: July 19, 2007 Model 129.068; Model 170.465; Model 171.454/456; Model 202.029; Model 203.052/054/056/061/064/081/084/087/092/261/264/281/284/764; Model 204.054/056; Model 208.365/370/465/470; Model 209.356/365/372/375/456/465/472/475; Model 210.065/070/082/083/265/282; Model 211.056/065/072/082/083/087/090/256/265/282/283/287; Model 215.376; Model 216.376/371; Model 219.372; Model 220.067/070/083/170/175/176/183/184; Model 221.171/176/186; Model 230.471/475/476/477 GROUP:07 - Mixture formation MERCEDES-BENZ:
Superceded Bulletin(s): P-B-07.00/57E, Date of Issue: December 21, 2007 Related Ref Number(s): 07.00/57D, 07.00/57E, 07.61/74
ARTICLE BEGINNING
SUBJECT
Model 129.068
Model 170.465
Model 171.454/456
Model 202.029
Model 204.054/056
Model 215.376
Model 216.376/371
Model 219.372
Equipped with Engine M112 / M113 / M272 / M273 or M275
Diagnosis in DAS for Purge System Codes / Check Engine Light Illuminated
If you receive customer reports in the above model vehicles of the check engine light being illuminated with stored fault codes for "Purge system minor / gross leak" (see following list) in the engine control unit, process the faults using the guided diagnosis in DAS. A guided diagnostic program for the fault codes listed below is available in DAS as of DVD 03/07.
NOTE: Only the parts indicated by the SDS test may be replaced. The engine control unit must not be replaced in the case of the fault codes listed below. All other components being replaced and requested by the QEC for inspection must be accompanied by full supporting documentation (i.e. control unit log, short test and fault code / freeze frame data from other related control modules). If the documentation is missing or does not support the diagnosis, the warranty claim may be debited.
CONTROL UNIT - ME 2.7.1 (MODELS 215, 220 AND 230) Fault text (as displayed in DAS) P2015 Purge control system has leak (function chain) (P0440) Fault Code
CONTROL UNIT - ME 2.7.2 (MODELS 216, 221 AND 230) Fault text (as displayed in DAS) P2013 Major leak in purge system (P0455) P2014 Purge control system has slight leak (P0422) P2015 Purge control system has leak (function chain) (P0440) P2075 Purge control system has slight leak (minor leak) (P0456) Fault Code
CONTROL UNIT - ME 2.8 (MODELS 170, 202, 203, 208, 209, 210, 211, 215, 219, 220 AND 230) Fault text (as displayed in DAS) P2013 (002) Major leak in purge system: Hose in system not connected or filler cap open (P0455) P2014 (002) Purge control system has slight leak: Leak in hose connection or shutoff valve of activated charcoal canister (P0442) P2015 (002) Purge control system has leak (function chain): Mechanical defect in component Y58/1 (Purge control valve) (P0440) Fault Code
CONTROL UNIT - ME 9.7 (MODELS 171, 203, 204, 209, 211, 216, 219, 221 AND 230) Fault text (as displayed in DAS) 1081 Purge control system has slight leak / Leak in hose connection or shutoff valve of activated charcoal canister (P0442) 1085 Fault Code Major leak in purge system / Hose in system not connected or
Page 3 of 3 DIAGNOSIS IN DAS FOR PURGE SYSTEM CODES / CHECK ENGINE LIGHT ILL ...
1089 Purge control system has a slight leak (minor leak) (P0456)
Dec 27, 2008 at 12:22 AM
