2004 Other Mercedes Benz Models radiator and transmission
2004 MERCEDES BENZ
31,000 MILES • V8 • 2WD • AUTOMATIC
RANDY TAYLOR
We are experiencing a slight hesitation. The mechanic said the radiator has a small leak and antifreeze is leaking into the transmission. Can this happen? How serious is the problem? The mechanic is replacing the radiator. Will this solve the problem? Is there a chance the transmission is damaged?
They will drain the transmission and replace the fluid, in addition to replacing the radiator,
May 15, 2008 at 5:09 AM
GFIMOTORCARS
  • 673 POSTS
Yes this absolutely can happen and the steps your mechanic is suggesting are the correct ways to remedy this problem.
Feb 28, 2009 at 4:07 PM
