2003 Other Mercedes Benz Models Smoking
2003 MERCEDES BENZ
RAHEEMELLIS
Engine Performance problem
2003 Other Mercedes Benz Models 6 cyl Automatic 79405 miles
I have a 2003 E320 Benz with 80,000 miles. I have had regular service. But it smokes a little while ideling and using passing gear. The smoke is blue in color and coming from exhust pipe out of rear. No smoke from under hood. No running issues. All fluids are good could it be gasoline? What is this? Please help me!
Thanks
Ray
May 10, 2008 at 9:26 AM
BLACKOP555
  • 10,386 POSTS
wheres the smoke coming from?
exhaust? under the hood?
color? odor? al fluids good? no issues with running besides the smoke?
May 10, 2008 at 11:05 AM
RAHEEMELLIS
[quote:ba59cf0b1c="blackop555"]wheres the smoke coming from?
color? odor? al fluids good? no issues with running besides the smoke?[/quote:ba59cf0b1c]
Thanks
Ray
May 14, 2008 at 12:36 PM
BLACKOP555
  • 10,386 POSTS
blue smoke indicates oil being burned, but since it is in such low quantities, it could be that your piston rings are slightly worn, but that is no problem. it could also be worn valve seals which could be allowing oil to get into the cylinder and burn.
May 14, 2008 at 11:57 PM
RAHEEMELLIS
[quote:dd7d3c36b7="blackop555"]blue smoke indicates oil being burned, but since it is in such low quantities, it could be that your piston rings are slightly worn, but that is no problem. it could also be worn valve seals which could be allowing oil to get into the cylinder and burn.[/quote:dd7d3c36b7]
Thank you so much for answering my questions!
Ray
May 15, 2008 at 11:40 AM
BLACKOP555
  • 10,386 POSTS
no problem.
and thank you very much for the donation!
May 16, 2008 at 12:14 AM
