2003 Mercedes C230 Brake Torque Specs
2003 MERCEDES BENZ
TINABROCATO
I have a 2003 Mercedes C230 Kompressor with 53,000 mi. and a 1.8L 4 Cylinder engine.
I need to know the brake torque specs in order to replace the front and rear break pads as well as front and rear rotors. Thank you!!
Jun 7, 2007 at 3:20 AM
2CARPRO JACK
  • 11,533 POSTS
Brake caliper @ steering knuckle- 85 ft lbs
Rear caliper mounting bolts- 41 ft lbs
Brake pad wear sensor bolt- 71 inch lbs
Front and rear disc locking bolt- 89 inch lbs
Wheel lug bolts- 81 ft lbs
Jun 7, 2007 at 4:19 AM
