2002 Other Mercedes Benz Models bumps
2002 MERCEDES BENZ
88,000 MILES • V8 • AWD • AUTOMATIC
MCOYLE
my e430 awd bangs and rattles over bumps. It seems as if the tires are skipping over minor bumps and I feel the steering is unstable when entring bumpy turns and off ramps. the ball joints have been replaced and the dealer states that the front struts are ok. the tires are new ( six months) but are wearing on the front outsides slightly. the steering wheel is off center. Can this be an alignment or tire issue?? I have adjusted the tire pressure accordingly.
Jan 2, 2008 at 1:43 PM
GFIMOTORCARS
  • 673 POSTS
I would definately have the front control arm bushings checked out as well as the thrust arm bushings. These bushings being severly worn will cause this complaint. Also the tire wear and steering may be alignment related.
Jan 5, 2009 at 1:59 PM
