2000 Other Mercedes Benz Models Limp Mode
2000 MERCEDES BENZ
RYAN DEUTROM
Engine Performance problem
2000 Other Mercedes Benz Models 6 cyl Two Wheel Drive Automatic 112K miles
Collected bad fuel & engine went into limp mode soon after, Changed Spark Plugs & Leads, Fuel cleaner additive used twice, EFU system clean out. Engine still goes into limp mode at around 5000rpm, any suggestions will be helpfull as this is getting very frustrating, Thanks Ryan
Nov 17, 2008 at 4:14 PM
GFIMOTORCARS
  • 673 POSTS
If poor fuel has been run in the engine you may have damaged the O2 sensors. If these are showing irradic readings it will cause the vehicle to go into limp home mode to protect the engine and catalytic converter.
Jan 3, 2009 at 1:32 PM
