2000 Other Mercedes Benz Models Engine dies when gets hot
2000 MERCEDES BENZ
DEBONAIRE4U2
Engine Performance problem
2000 Other Mercedes Benz Models Automatic 92147 miles
My mercedes benz ML430, dies when engine gets hot. What is the probbable cause?
Oct 21, 2008 at 12:54 PM
MASTERTECHTIM
  • 4,750 POSTS
if you are losing spark and injector pulse i find that the most common cause for this is to be a faulty crankshaft position sensor. when the sensor heats up the windings inside become open and then they reconnect when it cools. thats where i would start. hope this helps
Oct 21, 2008 at 1:02 PM
DEBONAIRE4U2
It did not show a fault code to my scanner?
Oct 21, 2008 at 3:46 PM
MASTERTECHTIM
  • 4,750 POSTS
if you lose spark then replace it. thats the only thing i have seen fail on the mercedes
Oct 22, 2008 at 12:36 AM
DEBONAIRE4U2
Thank very much for your time in answering the questions of my problem.
Oct 22, 2008 at 2:50 AM
