1999 Other Mercedes Benz Models engine kills
1999 MERCEDES BENZ
135,000 MILES • V8 • 2WD • AUTOMATIC
RCROCHET
recently my engine cuts off - I have noticed that once the engine temp rises above 90 degrees it will just shut off - once it cools - it starts right up
Sep 30, 2008 at 3:45 AM
AUTOEVOLUTION
  • 14 POSTS
Well first off, getting the codes pulled will help in figuring the problem out. There is usually a common problem in this type of symptom. Crank position sensors are a common failing part that causes this issue/symptom BUT only if the codes are corresponding. Most crank sensors will either have codes stored relating to the crank sensor or may not have any codes at all. If the vehicle has another code then your problem could be in another direction. Let us know what codes you have in order to determine the best possible cause/solution.
Oct 13, 2008 at 2:05 AM
