1998 Other Mercedes Benz Models gas cap
1998 MERCEDES BENZ
207,000 MILES • 6 CYL • 2WD • AUTOMATIC
RSC4133
I have a 98 E320. My gas cap is difficult to get off when trying to refuel. I replaced it about one month ago and the new fuel cap is doing the same thing. The gas tank neck does not appear to be bent or anything but I have to pry the cap off when trying to fuel up. As stated above, buying a new one did not rectify my problem. I feel that this is a bad design by mercedes. I noticed that the M320 has a different design that works with no problem. Has anyone had this problem and if so what did you do to correct this problem?
Nov 16, 2008 at 1:13 PM
GFIMOTORCARS
  • 673 POSTS
I have never heard of any consistent problems like this from MB. The gas caps are usually very well mated with the filler neck. Despite its none bent apperance I could pretty well assure you if you have had to pry on this to get it off that the filler neck is bent.
Mar 26, 2009 at 3:52 PM
