1993 Other Mercedes Benz Models Brake pad wear light in the
1993 MERCEDES BENZ
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
EOGUTVEREN
Brake pad wear light in the console is flickering, brake pads and this sensor senders are new but light still flickering when driving. it is a 300E 93 Model Mercedes
Jan 12, 2008 at 12:58 PM
  • 31,937 POSTS
One of the sensors is earthing out causing the light to come on, your mechanic will be able to isolate each sensor in turn to locate the problem.
Mark (mhpautos)
Jan 12, 2008 at 9:25 PM
EOGUTVEREN
Can the sensor be an ABS sensor instead of these senders, because light is comming with diffarent dimmness only when the car moving.
Jan 14, 2008 at 2:07 AM
  • 31,937 POSTS
If an ABS sensor is at fault, you would get a set fault code. Do you have any fault codes?
Mark (mhpautos)
Jan 14, 2008 at 3:33 AM
EOGUTVEREN
Hi Thanks for your replies, I do not know any codes , there is an ABS light and a red Brake light on the console but they are not illuminated.
Jan 14, 2008 at 8:26 AM
