1990 Other Mercedes Benz Models window
1990 MERCEDES BENZ
125,000 MILES • 6 CYL • 4WD • AUTOMATIC
DROSSMAN
We have a 1990 Mercedes 300E. The right rear window fell into the door. There is a "plastic" arm thing at the bottom that is broken. Is that the window regulator?
Oct 3, 2008 at 3:14 AM
GFIMOTORCARS
  • CAR REPAIR CONTRIBUTOR
  • 673 POSTS
Yes you are more than likely seeing a piece of the regulator. The rest of the regulator is rivited to the inside door frame. These will often times break causing the window to fall or become immovable.
Jan 6, 2009 at 2:41 PM
