1990 Other Mercedes Benz Models Rear Wheel Sway Under Power
1990 MERCEDES BENZ
215,000 MILES • 6 CYL • 2WD • AUTOMATIC
TG5457
My 1990 300CE sways and wiggles ONLY when the accelator is depressed and is most noticable as the speed increases. It will wiggle, sway and rock side to side in a rolling motion, which STOPS when I take my foot off the gas.
differential? axles?
Feb 1, 2008 at 10:21 AM
MASTERTECHTIM
  • 4,750 POSTS
there is a rubbr coupler that connects driveshaft to trans and rear end. one or both of yours is wasted. hope this helps
Feb 1, 2008 at 10:23 AM
TG5457
are you fairly confident that is the problem with the wiggle--could it be the differential itself?
thanks TG
Feb 15, 2008 at 10:10 AM
MASTERTECHTIM
  • 4,750 POSTS
most definately the rubber coupling is going to wear out before the rear end will. in my opinion.
Feb 15, 2008 at 10:14 AM
TG5457
the mercedes dealer replaced the differential bushings? is that one of the ends? so is it then the other end at ther transmssion?
Feb 15, 2008 at 10:16 AM
MASTERTECHTIM
  • 4,750 POSTS
it should be fairly simple to determine for any mechanic. differential bushings are not the same thing as the coupler. i dont know what else to tell you besides get another mechanic to look at it.
Feb 15, 2008 at 10:24 AM
TG5457
thanks again. i'll have them look it again this week. I've spent over $2000 at mercedes on 3 different returns visists tring to fix this issue. they repalces motor mounts, transmission mounts, diff bushings,
front sawy bushings, 4 new tires. this car by the way is in superb condition 100% mercedes maitained, no accidents, original owner and maintained with blank checkbook.
if this is the fix, i'll send youa nice donation!
TG
Feb 15, 2008 at 9:50 PM
