1990 Other Mercedes Benz Models air and heat not working
1990 MERCEDES BENZ
247,500 MILES • 6 CYL • 2WD • AUTOMATIC
MSPEAK
I have a 1990 300E with 247,500 miles. The heat and air quit working so I replaced the blower motor first (didn't fix problem) then I replaced the regulator. The air worked for about 3 minutes then the heat came on and I couldn't adjust the fan speed. So then I replaced the climate control unit with a brand new unit from mercedes (I intend to keep the car for a long time). Nothing at all works with the new unit installed but when I reinstall the old unit I get about 3 minutes of air then heat again. I've checked all the fuses. Any ideas, I'd appreciate any help. Thanks.
Aug 26, 2008 at 9:02 AM
MERLIN2021
  • 17,250 POSTS
You need to scan it with a MB impulse tester, once you have the codes, all thats left is part replacement, go to an MB shop and have it scanned, or buy a scan tool that can do it!
A/C-HEATER SYSTEM - AUTOMATIC -1990 Mercedes-Benz 300E
Page 1 of 1
NOTE: Before proceeding with test, check No. 7 fuse.
DIAGNOSTIC/IMPULSE READOUT TESTING
1.Connect Impulse Counter (013) to terminal No. 7 of diagnostic connector located in engine compartment. Turn ignition switch on. U BATT indicator light (LED) on impulse counter must be displayed. If LED does not light up, test voltage between terminal No. 1 (ground) of test connector and positive battery terminal. Voltage should be 11-14 volts. 2.Test for voltage between terminals No. 1 and 7 of test connector, voltage should be 6-12 volts. If voltage is not 6-12 volts, check wiring circuit. 3.Start impulse testing procedure. Press start button for no less than 2, but not more than 4 seconds. Observe and write down impulse readout code(s). 4.Press start button again for no less than 2, but no more than 4 seconds. If there are no further system malfunctions, the first indicated code will reappear. If trouble codes are present, repair as indicated. See IMPULSE DISPLAY CODES .
© 2007 Mitchell Repair Information Co., LLC.
http://www.ondemand5.com/mric/common/asp/printart.aspx
8/28/2008
Aug 28, 2008 at 8:24 AM
