1989 Other Mercedes Benz Models Timing belt
1989 MERCEDES BENZ
157,487 MILES • 6 CYL • 2WD • AUTOMATIC
STUGOTS1
How do i tell if my timing belt is bad. The car wont start but has fuel and spark. Would this be the timing belt
Apr 30, 2008 at 8:09 AM
  • 75,988 POSTS
Open up the distributor cap set it aside-crank engine over do you see the rotor turning if not the belt is gone or the distributor drive/gear sheared off-
Apr 30, 2008 at 8:59 AM
STUGOTS1
I have pulled the valve covers and distributor cap. The chain is not broken and the distributor turns fine. All ther valves seem to be working properly, thanks, Clayton.
May 2, 2008 at 12:00 AM
