1987 Other Mercedes Benz Models White Smoke From the exhaust
1987 MERCEDES BENZ
RSXVSCELL
Engine Mechanical problem
1987 Other Mercedes Benz Models 6 cyl Two Wheel Drive Automatic
hello , my name is alex , and i have mercedes 300e 1987 fuel not Sd, and i am facing a problem that my car is smoking white smoke from the exhaust when my rpm nearly fully loaded in it's ground not while moving , is this mean that i have a problem with my motor please help me with my problem , knowing that i want to know if the kind of oil affect in this problem , please help me .
2.and knowing that my rpm while the car is not moving at ( idle ) , sometime 8 , and sometime 12, and the mechanic solve the problem and after the heat of a motor the problem pre-exist and thank you .
Sep 14, 2008 at 9:46 AM
  • 31,937 POSTS
Hi there,
if your car is not using coolant and not over heating i would be checking the transmission vacuum modulator, as it may have a pin hole in it and drawing transmission oil into the engine, this will cause white smoke.
Mark (mhpautos)
Sep 14, 2008 at 11:40 AM
RSXVSCELL
hello again and thank you for your answer, but knowing that the white smoke is only when the car is idle not moving , when the car is fully speed loaded in ground not movie this white smoke comes from the exhaust , and i also please want to know if this problem occur when i put a regular oil and a synthetic oil type because now i have in my car 2 types of motor oil , and please i want to know what is the best oil type i can use for this car and thank you
Sep 15, 2008 at 6:43 AM
  • 31,937 POSTS
Hi there, engine oil will burn with a dark blue smoke, coolant, transmission oil and brake fluid will burn with a very white smoke, so get your mechanic to check this out.
Mark (mhpautos)
Sep 15, 2008 at 10:29 AM
