1987 Other Mercedes Benz Models Rear shock install on 1987 5
1987 MERCEDES BENZ
DSASLONG
1987 Other Mercedes Benz Models V8 Two Wheel Drive 150000 miles
Can you tell me where to look for the top of the rear shock on My 1987 560SL? I can not find the top of the shock
Thanks
May 18, 2008 at 12:50 AM
MERLIN2021
  • 17,250 POSTS
Some Benz models require the back seat to be removed, your could be in that catagory!
From MB:Loosen shocks only when vehicle is on the ground. On SL models with
removable top,remove top and open storage flap'
On all models, remove rear seat and backrest. On SL models, remove locking lever
from top flap and unscrew lining. On all other models, remove nut and rubber ring of
upper shock mount. Remove lower shock mount from semi-trailing arm.Remove shock in a
downward direction. Install is the reverse of this proceedure.
May 18, 2008 at 12:53 AM
