1987 Other Mercedes Benz Models Headlight
1987 MERCEDES BENZ
97,199 MILES • V8 • 2WD • AUTOMATIC
MWHIT1230
My passenger side headlight will not operate. I've checked/replaced the bulb and that doesn't seem to be the problem. Any suggestions?
Nov 24, 2008 at 1:47 PM
GFIMOTORCARS
  • 673 POSTS
I would recommend checking the light bulb connector. Remove the bulb from it's connector and look inside. If you see burn marks anywhere in the connector or corrosion then you are more than likely getting a poor contact with the bulb. To fix this you must replace the bulb connector.
Jan 3, 2009 at 1:25 PM
