2000 Mercedes Benz ML55 crank position sensor
111,000 MILES • V8 • AWD • AUTOMATIC
TDO326
how do you replace the crank position sensor and where is it located in the engine?
Jul 24, 2010 at 7:14 PM
  • 75,988 POSTS
Remove/Install Crankshaft Position Sensor Shown On Engine 113 In Model 220
https://images.2carpros.com/forum/automotive_pictures/12900_c_11.jpg
Work Instructions NOTE: Remove Air cleaner (engine side). Crankshaft position sensor to engine block - 8 N.m NOTE: If the crankshaft position sensor (L5) was replaced, a re-initialization must be carried out with STAR DIAGNOSIS in the menu item control module adaptations. https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Jul 24, 2010 at 8:28 PM
