2000 Mercedes Benz ML430 Shifts to Neutral
63,000 MILES • V8 • 4WD • AUTOMATIC
RLIPSKY1
Question 1
The car changes from drive to neutral at low speeds while turning sharp without anything touching the shift lever
Moving the lever has no effect - reverse works but nor drive
You have to turn car off then back on to get the car back in drive.
Question 2
When I fill the tank with gas, it ereads zero - after about 25 miles it reads normal. Any ideas
Dec 19, 2009 at 7:30 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
Both these problems i feel are electrical related, i would be thinking part of the loom for the transmission control system may be damaged through chafing on a bracket or body work and this is earthing out a signal to the transmission, as for the fuel sender, this may be a faulty sender unit in the tank i have seen this before in other makes of cars, very slow senders in the tank,
Have your Benz dealer or a trans specialist inspect the transmission problem.
mark (mhpautos)
Dec 22, 2009 at 1:25 PM
