serpentine belt diagram
140,000 MILES • V8 • AWD • AUTOMATIC
JASON Z
I would like the routing of the serpen belt the old one ripped of of my mother in laws truck. Thanks Jason
Feb 1, 2009 at 12:05 AM
GFIMOTORCARS
  • 673 POSTS
The belt routing is as follows Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
https://images.2carpros.com/forum/automotive_pictures/294900_Ml430_belt_routing_1.jpg
Mar 18, 2009 at 6:20 AM
KENDELL460
Engine Mechanical problem
2000 Mercedes Benz ML430 V8 Automatic 170000 miles
My belt in the engine broke and i put a new one on and it shredded apart. I beleive that it is missing a wheel thing that the belt runs on. I can not find what the engine is supost to look like? Is there supost to be a plastic wheel on the top (highest) wheel? cause all i have is metal no ribbed peice like all the others?
Dec 29, 2020 at 5:42 AM (Merged)
GFIMOTORCARS
  • 673 POSTS
There are smooth pulleys, these are the pullys that run the back side of the belt not the ribbed side. The following is the belt routing diagram for your vehicle. Look at the diagram to determine if the pulley you are speaking about is one the should be ribbed or not (the outer pulleys should all be ribbed side in). From your description it sounds like you are speaking of the Idler pulley which should have ribbing on it.
https://images.2carpros.com/forum/automotive_pictures/294900_Ml430_belt_routing_2.jpg
