2007 Mercedes Benz ML350 ingnition wont turn over
2007 MERCEDES BENZ ML350
50,000 MILES • 6 CYL • AWD • AUTOMATIC
LIOTTAS
The car will not start. engaged ignition sound(crank) but will not turn on. Car is in park, plenty of battery power, gas in tank.
Mar 11, 2010 at 7:04 AM
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Mar 11, 2010 at 7:09 AM
