2003 Mercedes Benz ML320 Steering trouble
84,000 MILES • 6 CYL • 4WD • AUTOMATIC
GRAYTRUCK
I have no power steering. When I parked the truck fluid was leaking from under the front of the truick.
What do I need to do?
Aug 7, 2008 at 12:29 AM
ROB2008
  • 258 POSTS
First thing I would do is pop the hood and find where the leak is coming from .Inspect the hoses and the power steering pump it self for leaks .Then you'll have a good idea of what to replace .
Aug 7, 2008 at 1:08 AM
ZOX989
  • 7 POSTS
[quote="Graytruck"]Steering problem
2003 Mercedes Benz ML320 6 cyl Four Wheel Drive Automatic 84000 miles
ML's have problems with p/s hoses coming off.There have been many updated hoses.Odds are you p/s hose came off at the radiator.You can check with your local dealer to see if they will replace it for free due to the numerous recalls.
Aug 25, 2008 at 2:20 AM
