2002 Mercedes Benz ML320 Brake Lights
95,000 MILES • 6 CYL • AWD • AUTOMATIC
EROCKS
I hope you can help. All three of my brake lights are "out" and wont activate when the brake pedal is depressed. I have replaced all three bulbs (none of which appeared burnt out) and checked the fuse. The fuse is fine and, even after bulb replacement, the brake lights will not come on. Any advice? Please help! Thanks.
Oct 6, 2010 at 8:15 AM
BMRFIXIT
  • 19,053 POSTS
Brake light switch is a common failure on the ML320
Switch located on top of brake paddle
remove cover to gain access
Oct 6, 2010 at 12:22 PM
