2001 Mercedes Benz ML320 replaced battery reset radio
JAYHH123
  • 2001 MERCEDES BENZ ML320
Computer problem
i recently replaced my battery in my ML320 and it reset the radio and I purchased the vehicle at carmax so I do not know the security code it is asking me for what should I do? Is there a default code?
Friday, October 22nd, 2010 AT 3:35 AM
  • 31,937 POSTS
Hi there, there is no default code, I would contact a dealer and see if there is code recorded against the chassis or VIN No, failing this the radio will have a serial no that the manufacturer should have the code on file.
Mark (mhpautos)
Friday, October 22nd, 2010 AT 5:22 AM
RHONDA1
That answer is incorrect. There is a card that comes with the vehicle showing the code that is needed for the radio/music system. I know because I have one.
Thursday, January 20th, 2011 AT 3:02 PM
  • 31,937 POSTS
You may still have your PIN, but the question was about a default code which there is none, if the PIN is not known there is no general default code and the PIN must be retrieved from Benz as it will be stored in the master data base.
Mark (Maputos)
Thursday, January 20th, 2011 AT 9:46 PM
