2000 Mercedes Benz ML320 REPLACING THE ALTERNATOR
2000 MERCEDES BENZ ML320
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
DAVETHEWAVE
IS THERE ANY SPECIAL TOOLS OR PROCEDURE FOR REPLACING THE ALTERNATOR ON A ML320. I KNOW HOW FINICKY BENZS CAN BE.
Mar 11, 2008 at 12:41 AM
GFIMOTORCARS
  • 673 POSTS
You will need a set of torx sockets to get the two mounting bolts out and a set of vise grips to push the retainers back into the mounts. Make sure you have the battery disconnected before you remove the alternator.
Feb 28, 2009 at 4:59 AM
