2000 Mercedes Benz ML320 MASS AIR FLOW SENSOR
110,000 MILES • 6 CYL • AWD • AUTOMATIC
RPSTARR
  • 10 POSTS
CHANGED MASS AIR FLOW SENSOR WHEN CAR ALMOST STOPPED RUNNING AND THREW CODE SHOWING MALFUNCTION IN MASS AIR FLOW SENSOR CIRCUIT - THOUGHT PROBLEM SOLVED - BUT CHECK ENGINE LIGHT IS BACK ON - SHOWS MALFUNCTION IN FUEL TRIM BANKS 1 & 2. AT FIRST THE CHECK ENGINE LIGHT WOULD GO OFF AFTER RUNNING THE CAR 3 OR 4 TIMES. NOW IT IS STAYING ON - SAME CODES - occasionally has a slight shudder at idle - DID I GET A BAD MASS AIR FLOW SENSOR ???
Jun 10, 2010 at 8:08 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Would you post code in P0xxx format so I may acess info for causes?
Thanks for donate
Jun 14, 2010 at 2:43 AM
RPSTARR
  • 10 POSTS
[quote:be76a819ae="Docfixit"]Hi
Thanks for donate[/quote:be76a819ae]
THE CODES WERE PO170 - FUEL TRIM MALFUNCTION (BANK 1) AND PO173 FUEL TRIM MALFUNCTION (BANK 2)
THESE CODES APPEARED AFTER I CHANGED THE MASS AIR FLOW SENSOR.
Jun 14, 2010 at 3:18 AM
DOCFIXIT
  • 18,828 POSTS
Was code P0100 present before replacing MAF? Recheck the instlation most common cause for 170-173 together is intake leak
Jun 14, 2010 at 3:51 AM
RPSTARR
  • 10 POSTS
[quote:fa8da6c3e8="Docfixit"]Was code P0100 present before replacing MAF? Recheck the instlation most common cause for 170-173 together is intake leak[/quote:fa8da6c3e8]
YES PO100 WAS PRESENT BEFORE REPLACING THE MAF - CHECKED INSTALL ON MAF AND IT APPEARS TO BE PROPER - CHECKED BELLOWS AND COULD FIND NO CRACKS OR SPLITS - ANY WAY TO CHECK FOR LEAKS ???
PROBLEM STARTED DURING WINTER - HAD TO WARM UP A LITTLE BIT OTHERWISE IT WOULD BOG DOWN - THEN ABOUT A MONTH AGO (WHILE DRIVING) IT STARTED BOGGING DOWN AND I ALMOST DIDN'T MAKE IT HOME. RAN THE CODES AND CHANGED THE MAF. EVERYTHING APPEARED TO BE FINE AND THEN 170-173 APPEARED AFTER SEVERAL DAYS. RAN THE DATA ON MY SCANNER AND IT SHOWS INTAKE AIR TEMPS THAT SEEM VERY HIGH (130-150)- THE TEMP HERE HAS BEEN IN THE MID 90'S !!!
Jun 14, 2010 at 5:22 AM
DOCFIXIT
  • 18,828 POSTS
Have fuel pressure tested maybe faulty diaphram pressure regulator lowering fuel pressure
Jun 14, 2010 at 5:52 AM
