CHANGED MASS AIR FLOW SENSOR WHEN CAR ALMOST STOPPED RUNNING AND THREW CODE SHOWING MALFUNCTION IN MASS AIR FLOW SENSOR CIRCUIT - THOUGHT PROBLEM SOLVED - BUT CHECK ENGINE LIGHT IS BACK ON - SHOWS MALFUNCTION IN FUEL TRIM BANKS 1 & 2. AT FIRST THE CHECK ENGINE LIGHT WOULD GO OFF AFTER RUNNING THE CAR 3 OR 4 TIMES. NOW IT IS STAYING ON - SAME CODES - occasionally has a slight shudder at idle - DID I GET A BAD MASS AIR FLOW SENSOR ???
Jun 10, 2010 at 8:08 AM
