2000 Mercedes Benz ML320 Brakes
2000 MERCEDES BENZ ML320
92,000 MILES • 6 CYL • AWD • AUTOMATIC
DALECLARK
smoking brakes front right
What all should be replaced?
Jul 1, 2008 at 4:49 PM
GFIMOTORCARS
  • 673 POSTS
If your right front is smoking you may have a failed caliper piston. This will require replacement of the brake caliper. This is not a difficult job to do if you are mechanically confident. It will require bleeding of the brake system after the repair.
Feb 27, 2009 at 3:34 PM
