1999 Mercedes Benz ML320 Transmission
1999 MERCEDES BENZ ML320
215,000 MILES • 6 CYL • 2WD • AUTOMATIC
DLYNCH
When I press the gas there is a popping noise on the driver side. Is it the axle, joint, or transmission? Or is there something else casuing the problem?
Jan 4, 2010 at 8:16 AM
DAVE H
  • 13,384 POSTS
Hello . thanks for the donation .. much appreciated check the engine and transmission mounts, drive/axle shaft's, CV joints and suspension/steering mount's and bushing's/sway bar links etc. Hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_946.png
Jan 5, 2010 at 7:37 PM
