1998 Mercedes Benz ML320 fan blade
151,000 MILES • 6 CYL • 4WD • AUTOMATIC
JK24
I HAVE A 1998 MERCEDEZ ML 320 I NEED TO REPLACE THE WATER PUMP,DO I TAKE OFF THE FAN BLADE FIRST CONNECTED TO THE WATER PUMP PULLEY ,THERES A BIG NUT CONNECTED TO THE PULLEY AND THE BLADE I DONT KNOW WHAT SIZE TO USE I BOUGHT A 12 INCH CRECENT WRENCH IT WAS TOO THICK CAUSE THE ALLEN WRENCH BOLTS CONNECTED TO THE PULLEY ARE IN THE WAY OF THE NUT. THANKS FOR YOUR TIME.
SINCERELY, JEFF KILLINGBECK
Jun 10, 2008 at 5:51 PM
ZOX989
  • 7 POSTS
[quote="JK24"]Engine Cooling problem
1998 Mercedes Benz ML320 6 cyl Four Wheel Drive Automatic 151000 miles
There are two special tools needed.thin wrench ,part number - k-d3136 usa from snap-on, a 3 hole spanner wrench to hold the bolts on the pulley.
Aug 25, 2008 at 2:12 AM
