1998 Mercedes Benz ML320 door lock
OUTBACK REPAIRS
Interior problem
1998 Mercedes Benz ML320 All Wheel Drive Automatic 240000 miles
driver door lock was going crazy each time doors were to lock, now driver door is locked and willnot unlock electronically or with key or manually? where do I start?
Apr 22, 2010 at 1:07 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the door lock actuator may be bad.You will need to remove the door panel to get to the actuator so that you can remove it to see if the lock will then work manually (with key) if not the lock assembly may be bad, causing the power lock to freak out
Apr 27, 2010 at 3:24 PM
