What's the trans fluid change procedure? I have the pan gasket and fluid. The trans has no drain, where is the fluid added?
Also whats the correct procedure and tools necessary to get to and change the upper O2 sensors. The drivers side access is very limited.
I also want to change the plugs, your suggestions to help with access and procedure will be greatly appreciated.
I am mechanically inclined with a fairly well stocked roll away.
Thak you in advance.
Ken
Ken
Feb 15, 2010 at 8:33 AM
