2000 Mercedes Benz E430 What causes the transmission to ope
SWAY3511
2000 Mercedes Benz E430 V8 Four Wheel Drive Automatic
I was griving and the transmission was engaged in a limb home mode meaning it was only operating in tha 2ND and reverse gears. The problem was diagnosed as trans oil leak into the trans plug. The seal was replaced and the plug was also changed but the transmisson is still operating in the same limb mode. What is the next component to look at?
Aug 8, 2010 at 1:42 AM
  • 31,937 POSTS
Hi there,
can you post the fault code set in the ECU, this will help with the diagnosis.
mark (mhpautos)
Aug 8, 2010 at 1:47 AM
