Hello -
Thank you very much for the info........
The diagram I was referring to is the wiring diagram for your vehicle.............
I was checking to see if there were any indication lights on the dash, the door ajar in this case to see if the door switch was not working correctly. Many times the door switch controls both the interior lights and also tells if the door is ajar.........since you don't have any indication on the dash of a door being open........that provides more info.
Thank you for the info on the rear doors only.........
Are you pulling Fuse C, a 16amp fuse to turn them off?
It appears that the wiring diagram shows both rear doors go through a rear dome light switch. Are you sure the rear dome light is not burnt out and the switch has been turned on since it just started?
If this is okay my suggestion is to remove each rear door switch one at a time. Disconnect the connector and see if the light goes out, then jump the wire and see if they come on. Let me know what you find out.
Aug 5, 2009 at 2:07 PM
