1999 Mercedes Benz E320 1999 MB 320 Misfire codes P0304 thr
1999 MERCEDES BENZ E320
60,000 MILES • 6 CYL • AWD • AUTOMATIC
RLCOFMN
I have an 1999 MB E320 4-matic, which has the Check engine light on! I have read the diagnostic with OBD 2 reader and it it showing P0304 thru 6 error codes. Which I'm sure you're aware is all of Bank 2. My intuition would lead me to believe it is something in common with all 3 cylinders. The Bank 2 Sensor 1 was reading 0 mV and has been replaced but has not changed the misfire condition. Plugs and wires were replace 9 months ago with also the crank location sensor. What else could cause an entire bank to misfire. Or am I barking up the wrong tree? Thanks
Aug 26, 2010 at 10:28 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
The most likely fault here would be the ME-SFI control module seeing as how the plugs and wires have already been replaced.
Aug 31, 2010 at 3:36 PM
RLCOFMN
But why would a faluty ME-SFI only have misfires on one bank?
Sep 2, 2010 at 7:20 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The control module could still be signaling the other bank. Have you inspected the MAF sensor by any chance? A faulty MAF sensor will sometimes cause this issue as well. It could even be a fault with the fuel and not the spark. If MAF is found good than may need to check the fuel injectors on that bank.
Sep 3, 2010 at 4:53 AM
