1998 Mercedes Benz E320 Valve Cover Gasket
1998 MERCEDES BENZ E320
175,000 MILES • 6 CYL • 2WD • AUTOMATIC
JEFF HAYDEN
I notice an occasional smell of oil burning and experience a slow leak between oil changes. Very little is visible below car so I feel like this may be a slow valve cover leak that is being burned off on the manifold. I wanted to find information about valve cover gasket replacement or other potetial causes of this problem.
Aug 2, 2010 at 1:38 PM
  • 31,937 POSTS
Hi there,
If you remove the air filter housing you should be able to see any weeping from the rocker cover, this is a rubber type gasket so you may be able to just nip the bolts down a little if there is any evidence of leaking, look at this first.
mark (mhpautos)
Aug 2, 2010 at 10:20 PM
