These filters are one in the same one your vehicle. You can access these filters by removing your glove box. Open the glove box door and find the 6 retaining screws. 2 located on the top inside of the glove box. 2 located on the bottom floor of the glove box and two on the sides. Remove these screws and pull out glove box. The filters are located directly behind the glove box. You will see a plastic door to remove. The filter is located inside.
Jan 29, 2009 at 3:03 PM
