1995 Mercedes Benz E320 ac not working
1995 MERCEDES BENZ E320
198,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOB HUDSON
had compressor checked, it is good. twin cool down
fans are not working but wired directly they work,
blower inside works find. Is there a sensor or
switch burned out?
Thanks for your help
Sep 7, 2010 at 2:35 PM
MADMIKE1735
  • 951 POSTS
is the compressor engaged???? if not, may be a high/low pressure switch.... what are the pressures??? lowside should be between 40-60 and highside should be at around 150. there shouldnt be twin fans for your condensor, only one... the other fan cools the radiator..... have your system evacuated, and recharged to correct amount..... a switch only tells the compressor not to work if there is too much, or too little pressure.... your condensor fan may have alot to do with your problem.
Sep 7, 2010 at 2:41 PM
