1995 Mercedes Benz E250 gauges
KEBAB
Electrical problem
1995 Mercedes Benz E250 Two Wheel Drive Automatic
tempature gauge not working
Jan 15, 2010 at 12:54 AM
AUTOMD
  • 50 POSTS
I had similar problem. I replaced the sender unit but it doesn't work. Then I realized to removed the gauge from the instrument panel and tested it with 9V battery and it worked fine. After refitting gauge back to instrument panel it has worked ok since then. I assume there was just some contact problem in the panel. Try to check it.
Feb 4, 2010 at 4:38 PM
