2005 Mercedes Benz E200 engine misfire
51,000 MILES • 4 CYL • 2WD • AUTOMATIC
AZHARA62
My mercedes engine misfire while driving and the engine sign at the dashboard turn on and the engine shake while driving and while idle. I think it misfire when i accelerated the car. After i stop the car for about 1 hour, the engine sound ok(no misfiring and not shaking) when i started the car. After driving for a while, it misfire again. Would appreciate your expert opinion.
Aug 29, 2009 at 2:46 AM
  • 75,988 POSTS
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Aug 29, 2009 at 8:53 AM
