1996 Mercedes Benz E200 starter motor
1996 MERCEDES BENZ E200
ZD1
Engine Mechanical problem
1996 Mercedes Benz E200 4 cyl Two Wheel Drive Manual
hi my starter motor was not engaging so it wouldnt start so i changed starter motor and is doing the same
Apr 3, 2009 at 5:10 AM
BLUELIGHTNIN6
  • 16,542 POSTS
If starter motor is OK but is not engaging, inspect starter relay.
Thanks for using 2CarPros.com!
Apr 3, 2009 at 6:38 AM
ZD1
it is engaging sorry but its not spinning
Apr 8, 2009 at 4:26 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Check battery connections, solenoid contacts and starter motor connections for properly tightened and cleaned connections.
Apr 8, 2009 at 6:04 AM
