1981 Mercedes Benz E200 ENGINE MISFIRES AT HIGH SPEED OR AF
1981 MERCEDES BENZ E200
25,360 MILES • 4 CYL • 2WD • MANUAL
MWACHEDA
merc 123 - 230 - when am on high speed over 80kph engine starts having mises /chokes and when climbing a hill until the vehicle starts jerking. What is the cause
Apr 29, 2010 at 10:26 PM
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Apr 29, 2010 at 11:12 PM
