2005 Mercedes Benz CLK320 Can't remove the tires and wheels
40,000 MILES • 6 CYL • 2WD • AUTOMATIC
BRACKENB
We just purchased a 2005 Mercedes CLK 320. My husband does most of our upkeep on our vehicles. However, he can't get the wheels and tires removed from this car to rotate them. Is there a trick to it? He says it's almost like they are superglued. Need help!!
Feb 1, 2009 at 6:34 AM
GFIMOTORCARS
  • 673 POSTS
They should come right off with all the wheel lugs out. owever often times rust gets between the brake rotor and the wheel making it difficult to remove the tires. Try using a rust penetrant behind the wheel. Also if you have a rubber mallet you can hit the wheel from the backside, this sometimes helps.
Feb 15, 2009 at 1:36 PM
